Vehicle Speed Sensor in tranny, what for?
Old Jun 25, 2006 | 11:31 PM
lglamb's Avatar
2001 truck, what purpose does the tranny mounted Vehicle Speed Sensor
serve?
Only mention I've seen concerned shift points, but tranny pretty much
shifts ok and TC locks decent. (Really poor fluid coupling until then, tho.)
Been reading the VSS on the diff does the speedo and ABS and etc.
Getting VSS codes but everything seems to be working ok. Thot cruise
control went out, but bought a new VSS and the cruise started working
again. (didn't install new VSS, just wiggled a bunch of lines)
Also getting some dead pedal and 0216. New lift pump helped some, but
not all. Any chance the VSS might affect the VP44 somehow? Please?
Thanks,
Lowell
Old Jun 26, 2006 | 10:22 AM
1-2-3's Avatar
Just a plain ole guy
The speed senso tell the brain what speed your going so it knows when to shift. You kinda need it.
Old Jun 26, 2006 | 05:01 PM
lglamb's Avatar
Thanks.
Went ahead and put the new one in. Only had to replace a cup
or two of tranny fluid, not as bad as I'd thought.
Connector had so much grime built up in it that it wouldn't fit
onto new sensor. It was barely/maybe in the old one. Cleaned
it out good and snapped it in.
Don't know yet if it helped shifting any better.
Still got VP44 appointment. Oh, well.
Lowell
gator6
Nov 23, 2007 12:21 PM
04ctd
Nov 12, 2007 02:17 PM
torrey
Oct 25, 2006 07:42 PM
Dulley4x4
Mar 2, 2006 07:06 PM
phishsandwich
Oct 11, 2004 08:15 PM
