valve body question
Old Jan 19, 2009 | 01:42 PM
DMcPherson's Avatar
valve body question
I did a transgo kit and went out 4 turns on the pressure and .096 on the lockup orifice. I can still shudder the converter. how far can I go on the pressure? I want to go to probably .125-.150 on the converter pressure but will upping the line pressure also help? will I need a resistor to the tcm?
Old Jan 19, 2009 | 04:45 PM
j-fox's Avatar
You are at the edge of needing a resistor. I see you have a billet cover! I though that is the answer to slipping converters!!!! I'm just being a SA.
Maybe you have glazed the clutch already.
Old Jan 19, 2009 | 04:55 PM
DMcPherson's Avatar
if i go 1-2-3 to lockup its fine its jumping on it in lock up, it chatters. and thats on the comp or dyno tune on the adrenaline. so can I go another turn out on the vb? Im definitely going up to at least .125 on the vb pressure
Old Jan 19, 2009 | 07:56 PM
dozer12216's Avatar
Are you running with good ATF+4. Tranny needs more gonads to handle engine power. JMHO and converter clutch is probablly smoked.
Old Jan 19, 2009 | 08:13 PM
DMcPherson's Avatar
um yes fluid is good. converter is brand new. obviously trans needs more "gonads" this is why I have a custom built converter and valve body, just trying to get pressures right.
so again, does anyone know how far out I can go on the line pressure screw? and if i go any farther if Im going to need a resistor the the tcm, and what kind and where would it go if I do
Old Jan 19, 2009 | 11:20 PM
j-fox's Avatar
Put it together and read the line pressure and get back to us. By about 70 or so it will need the resistor, or a VR from Dtt.
Old Jan 20, 2009 | 07:15 AM
DMcPherson's Avatar
will do thanks
Trooperthorn
Jan 7, 2011 12:55 AM
jj3500
Jul 12, 2009 03:59 PM
12ValverDave
Nov 15, 2008 03:50 PM
OT-OF-Here
Feb 8, 2005 11:19 AM
