Valve body issue
Old Feb 1, 2008 | 02:43 PM
fordkiller43's Avatar
Valve body HELP!
So I just put my suncoast valve body in and I am havin some issues. When I first too the truck out for a test drive everything was great. I took it to work the next morning and heck broke loose. If I am at an intersection and turn either left or right my truck feels like it shifts to neutral going from first to second gear. If I stop at a stop sign and drive straight there is no slip. Its only when I am turning from a dead stop. It almost feels like the trannys slipping. I did a front band adjustment and it did not help the issue. Does anyone have any suggestions on what this might be and how to fix it. I hope I dont have a faulty VB. Everything else works great except for that first to second shift turning. Any ideas fellas? Thanks!
Old Feb 1, 2008 | 04:18 PM
BigB82789's Avatar
Got enough fluid in it? Maybe turning would slosh the fluid around...
Old Feb 1, 2008 | 04:28 PM
scottsjeeprolet's Avatar
It's not in 4x4 is it? could have accidentally shifted without your knowing.
If not suggest you contact Suncoast.
Old Feb 1, 2008 | 06:22 PM
Well just checked the fluid again and its halfway between low and full. Think that could cause it fellas? Thanks y'all for youre help!
Old Feb 1, 2008 | 07:23 PM
K this is whats goin on fellas..... The fluid level was reading halfway in between min and max. I just filled it up to max and the problems fixed. I talked to a suncoast rep and they said I was starving the valve body when the fluid washed to one side while I was turning. I cant beleive I pulled a newbie! hahaha... But at least its fixed. Thanks a lot fellas for all y'alls help!
Old Feb 1, 2008 | 09:21 PM
BigB82789's Avatar
Yep, them suckers hold alot of fluid, especially with a deep pan.
Old Feb 2, 2008 | 12:07 AM
caleb_s's Avatar
glad to hear you got your problem solved fordkiller43..how do you like the new suncoast??
Dynocon
Jul 3, 2014 07:49 PM
Trooperthorn
Jan 7, 2011 12:55 AM
jj3500
Jul 12, 2009 03:59 PM
12ValverDave
Nov 15, 2008 03:50 PM
