Valve adjustment article pics not showing
Old Sep 16, 2006 | 08:28 PM
hopak's Avatar
Is it my computer ? Definately would like to have them available before I start.
Old Sep 16, 2006 | 08:36 PM
Charlie8301's Avatar
it's working for me, try here
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Randy
Old Sep 17, 2006 | 06:09 AM
jrs_dodge_diesel's Avatar
Wierd. Even wierder is that only one of the four pictures show up for me .
I am the one that wrote that article, and I still have the pictures so I will post them here for you.
1. Fuel pump drive cover.
Disconnect the breather tube from the fitting. Then unscrew the plastic cap and this is what you will see:
2. TDC (top dead center) timing alignment.
Use a mirror and bar (hand crank) the engine to line up the notch with the line on the drive gear. The BDC (bottom dead center) notch is on the opposite side of the "hole" and is marked BDC on the timing cover.
Valve layout.
This is the valve layout. The shorter rocker arm is always for the intake valves. The longer one is always for the exhaust valves. I highlighted the injector for reference.
4. Measuring valve lash.
Insert the feeler guage between the pivot stud and the Y bridge.
5. Setting the valve lash.
If you have any questions on the procedure, please let me know.
Old Sep 25, 2006 | 07:22 AM
Marine's Avatar
Veteran: Marine Corp
I adjusted mine at 45,000.
Old Sep 25, 2006 | 08:09 AM
daysel's Avatar
Anyone ever tell a difference after doing this?
Old Sep 25, 2006 | 08:34 AM
GSP's Avatar
GSP
I adjusted mine at a little over 100,000 and they were all pretty much right on anyway
Old Oct 6, 2007 | 11:37 PM
dodgediesel's Avatar
Great info, thanks for saving me $150.00. That is how much they charge for a valve lash set!!!
Dean Snow
Nov 1, 2009 04:48 PM
tx_2500
Mar 28, 2007 10:28 PM
loosendend
Sep 4, 2006 12:01 PM
Greenhornet1986
25
Apr 20, 2006 02:34 PM
RowJ
Jan 28, 2005 08:19 PM
