vacuum pump and blow by
Old May 28, 2007 | 09:22 PM
Tony R's Avatar
i was wondering if anyone has ever had the problem with a vacuum pump pressurizing the crankcase causing excessive blow by and what was done to determine this as the problem on a 24 valve mine is really bad but havent lost any performance out of the engine runs great no smoke etc im opened to ideas here
Old Jul 10, 2007 | 04:25 PM
scout98's Avatar
Tony
did you ever locate your problem im having a simular problem
Old Jul 10, 2007 | 08:34 PM
garybg1's Avatar
I thought I had excessive blow by but it turn out to be the seal between the powersteering pump and the vacuum pump. I looked like it was blow by because they are so close together. Easy fix with a seal kit.
Gary
jimbo486
May 8, 2016 06:07 PM
Bobcat
Jan 17, 2014 04:27 PM
dzl_damon
Mar 19, 2010 05:17 PM
