Turbo Boost
Old Feb 19, 2003 | 03:45 PM
TEDHRS's Avatar
Turbo Boost
How much boost does the stock HX-35 put out?
Old Feb 20, 2003 | 12:12 AM
BigK's Avatar
Re:Turbo Boost
Gauges on the way. I'll let you know when they're in!
Yes, should have been done long ago!
Old Feb 20, 2003 | 12:50 AM
KATOOM's Avatar
Re:Turbo Boost
With guages you should see @15-18psi boost.
Old Feb 20, 2003 | 01:06 AM
DarrellB's Avatar
Re:Turbo Boost
A stock HX-35 can be run up to 30lbs, any thing more than that and it's actually hurting your EGT's.<br><br>DB
Old Feb 21, 2003 | 02:20 PM
forresthayes's Avatar
Re:Turbo Boost
I've peaked as much as 45lbs but after my last mod I run consistant 30lbs all day long. I do have the 16cm non wastedgated housing which helped the EGT's quite well but I can still overtemp if I stay in it to long. I know some guys peaking over 50 with the same set up.<br>
Old Feb 21, 2003 | 05:28 PM
BigBlue's Avatar
Re:Turbo Boost
I've run a consistent 35 psi out of mine and get the same EGT's that I do running it at 30 psi. Stock should be about 18-20. It is supposed to set a code at anything over 20, but I've had mine up to 22-23 before with no code.
97dodgeram2500
Nov 1, 2009 11:51 PM
jcarrillo
Jul 10, 2009 08:24 PM
JSCumms2000
13
Sep 24, 2008 05:46 PM
vwjunkie53
19
Nov 9, 2007 02:27 PM
Bobcat698
18
Oct 22, 2005 12:27 PM
