Charging Question
Charging Question
When I first start the truck I noticed that it was not charging enough. It would read between 10 & 12volts. As the ruck ran abit (under 1 min.) the guage would go up to normal charging. The headlights would confirm for me by getting brighter that the reading was correct. Is this normal,if not any ideas?<br> Thanks
Re:Charging Question
Your intake grid heaters come on below (I think) 50 degrees. They'll cycle for 3 minutes or until you exceed 18-20 MPH. They have a pretty high draw, which you'll see in the voltmeter and vehicle lights. This is completely normal and you should only worry if it's cold and you DON'T get the cycling.<br><br>As your batteries get older, you'll even get a check engine light as the initial draw brings them down below 10 volts. Mine are getting to the point where I'm going to have to start looking for new ones. 5 years isn't too bad though!
Thanks for the help, I feel much better now. My usual reaction would be to get another alternator or something, but due to the knowledge of the people here I haven't wasted money.....more for Bombing ;D
Diesel-Dan
20
Sep 22, 2019 09:34 PM
GLHS
Feb 25, 2011 10:12 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
robox
Feb 23, 2007 09:30 PM
