turbo
Old Jul 31, 2005 | 11:05 PM
smokNjoe's Avatar
turbo
i just took out my sillencer ring and noticed oil in my comp side of the turbo what would cause this and could it be the return line is cloged? how hard would it be to fix?
joe
Old Aug 1, 2005 | 01:41 PM
smokNjoe's Avatar
so know one has an idea that is a first
Old Aug 1, 2005 | 05:59 PM
mooseman's Avatar
I seen oil in mine also when it was new. The dealer told me it was normal seapage past bearings and seals.
A little oil haze should be nothing to worry about. Oil running into your intercooler would be a problem.
Mooseman
Old Aug 1, 2005 | 11:28 PM
smokNjoe's Avatar
thanks now i will sleep better tonight
Old Aug 2, 2005 | 12:40 AM
Mike Perez's Avatar
Mine has it too, and if you have a K&N filter, over oiling will do it too.
MP
Old Aug 2, 2005 | 08:26 PM
Geico266's Avatar
Not a bad idea to clean the oil out of the tubes leading to the boot & inner cooler. I do it about once a year. I've had the boot slip off twice so since then I inspect & clean once a year.
Old Aug 2, 2005 | 08:59 PM
newriverSpecon's Avatar
Makes an odd sound when they come of under pressure doesn't it? Our 4BT did it to us a couple of time at max PSI going up a 6k' hill.
Randy
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
