Truck wont start!!!!!!!!!!!!!
Old Nov 5, 2005 | 10:55 AM
one54ton's Avatar
Exclamation Truck wont start!!!!!!!!!!!!!
Heres the deal, last night I went to start my truck after just driving it and nothing...not even a crank. I could hear the pump turn on but thats its. No warning lights or anything came on. Could this be the starter or something way worse - Chris
Old Nov 5, 2005 | 11:25 AM
John Faughn's Avatar
Its normal for a starter not to do anything and something els like the lites to work , the starter will draw a lot of amps 600-800 and a lite as little as a couple amps so when like you when you've got a dead battery or bad connection it will only pass a little current , so 1st is how old are the batteries , starter, altanator , have them load tested , look at the connections are they clean , then look around for the upgraded starter conntacts they can cause this also , then you get deeper by checking the ignition switch, nutural safty switch ,but after the 1st stuff.
Old Nov 5, 2005 | 12:45 PM
one54ton's Avatar
will do thanks
Old Nov 5, 2005 | 03:30 PM
one54ton's Avatar
Looks like its the ignition or neutral safety switch. My batteries are fairly new, I have power to my starter, and all of my alternator connections are good. Im goin deeper into it tommorrow.
Old Nov 5, 2005 | 07:27 PM
firestorm's Avatar
Check your starter relay under the hood, in the fuse box.
rustydeeretech
Jun 16, 2010 09:41 AM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
doodah
Dec 15, 2002 05:03 AM
Desert Diesel
Dec 5, 2002 08:53 PM
