trouble starting
Old Mar 11, 2010 | 10:03 PM
silotree's Avatar
trouble starting
my truck will just sit there and turn over and not start. when you let off the key u can hear something humming under the hood. then when u try to start it a couple more times it will start. i am just confused
Old Mar 12, 2010 | 04:25 AM
dozer12216's Avatar
Try parking downhill with a relativelly full tank of fue. If it starts normal, this indicates a air leak into the fuel return system.
Frequent issues is: Loose banjo bolt at rear of head. Loose three way fitting at left rear side of block. A connector tube Oring leak. The rest of banjo bolt fittings..Sometimes you will find a very small dampness at area of air leak.
Old Mar 12, 2010 | 05:24 AM
Ram1999's Avatar
Fuel filter been changed lately? It could be clogged. Do you have a fuel pressure guage? If not...they are worth having.
Old Mar 13, 2010 | 09:14 PM
silotree's Avatar
ram1999 i changed my fuel filter today and it seemed to work for now thanks for all of your help both of you guys
ridlangus123
Dec 30, 2013 08:36 PM
salty mule
Jan 6, 2004 10:48 AM
nancym
Aug 24, 2003 09:11 PM
huntin2235
Aug 8, 2003 09:42 AM
hlc
Jan 26, 2003 09:16 AM
