Trouble starting
Old Aug 7, 2003 | 04:01 PM
huntin2235's Avatar
Trouble starting
???I just had my lifter pump replaced 3 days ago by the dealer. Last night I went up the mountain and turn it off came back and It wouldn't start. After about 4 attempts it started but, I have never had any problems starting before. Also my check engine light came on to boot....Any ideas what the cause might be????????
Old Aug 7, 2003 | 06:27 PM
chuck3's Avatar
Re:Trouble starting
It could be a lot of things but since your lift pump was out, I hate to say this but it could have taken out your injection pump.
Old Aug 8, 2003 | 06:44 AM
Smokee's Avatar
Re:Trouble starting
Using the principle of simple things first, check for a very small air leak...something like a line that is not really tight.
The lines may be sucking air when the engine cools.
george
Old Aug 8, 2003 | 09:42 AM
StakeMan's Avatar
Re:Trouble starting
If the check engine light came on then a code has been set.
Turn the key on 3 times. Leave it on the third time. Codes should be dispalyed in the odometer window.
Tells us what the codes are.
ridlangus123
Dec 30, 2013 08:36 PM
n.c.moutainman
Jan 16, 2005 11:22 AM
salty mule
Jan 6, 2004 10:48 AM
nancym
Aug 24, 2003 09:11 PM
hlc
Jan 26, 2003 09:16 AM
