trouble
Old Apr 5, 2011 | 06:23 PM
edgepower99's Avatar
trouble
I'm on a training trip I'm 200miles away from home and my 99cummins with an auto in it really wants to pull at a stop. The EGTs r reading like 800 degrees anyone have a idea what's up and what if any I can do 200miles away from home with no tools
Old Apr 5, 2011 | 07:31 PM
gorms's Avatar
Sounds like the torque converter clutch isn't totally unlocking, tough to fix without tools. Check transmission fluid to make sure it isn't something easy. Other wise I would try to get it in neutral if you need to stop, not very good for the the fluid to keep something slipping all the time.
Old Apr 5, 2011 | 08:40 PM
That's what I thought to is the torque converter wasn't fully disengaging. I can pop it in neutral to stop and when I put it back in drive it snubs the motor. I don't have to drive it until Friday when I go back home
Old Apr 5, 2011 | 09:26 PM
checked the tranny fluid its a little burnt but what do you expect with whats happening to it. the fluid is in the normal range so it must not be fully disengaging. what do I have to do when I get it home to fix it
Old Apr 6, 2011 | 03:21 PM
gorms's Avatar
Most likely needs a new torque converter, sometimes they just lock up. Who knows you could get lucky with a flush and new filter, but I seriously doubt it.
Old Apr 10, 2011 | 12:53 PM
I drove the truck 200 miles and got it home in one piece. Now i'm trying to do some research on the torque converter and some people are telling me that there is a torque converter lock up switch that could have went out causing my problem. I'm not to famliar with the tranny yet but is there one on the truck and where do i find it?
Old Apr 10, 2011 | 01:02 PM
torquefan's Avatar
I have seen this problem on a truck myself a couple years back, and read about several more on here lately. Seems to me it could be caused by the lockup solenoid sticking, or an internal converter problem. Haven't heard what any of these cases actually turned out to be though.
Old Apr 10, 2011 | 06:34 PM
gorms's Avatar
Check for any codes. The switch you're talking about might be the "mystery switch", an add on a few folks add to bypass the computer and lockup the torque converter clutch manually. If I recall, my truck threw a code when I put the switch in, because the "transmission relay" in the power distribution box gets jumped out in order for the switch to work at all times. Add on wiring tends to be the first to go (no offense, previous owners maybe?) and if there was a switch put in at one time, it works by grounding the #11 wire (orange?) out of the middle connector of the PCM. If the added wiring is grounded out (even if the switch is removed) it could lead to this situation.
Overdrive, torque converter clutch lockup, and line pressure regulation are all controlled through 3 solenoids on the valve body, so it its possible for one to be sticking. I think the o/d and tcc solenoids come in one package, so you could try a flush with new solenoids/filter etc. to see if that is the problem before you pull the transmission. They bolt onto the exterior of the valvebody, so not a very big job. Good luck.
ridlangus123
Dec 30, 2013 08:36 PM
moss2904
Jan 3, 2003 03:27 AM
ts
Dec 10, 2002 11:35 PM
boehunter49
Dec 4, 2002 05:57 PM
sprintcars
Dec 3, 2002 05:11 PM
