Transfer Pump Relay Code
Old Feb 9, 2010 | 06:50 PM
coreyb64's Avatar
Exclamation Transfer Pump Relay Code (HELP)
So my lift pump is getting no juice at all, just a small spurt when i turn the key. I checked for codes and pulled up the transfer pump code, has anyone had this happen before? Whats some ideas on solving this problem?
Old Feb 10, 2010 | 07:15 AM
dozer12216's Avatar
Well, when you turn the key on, the pump will only run for 2 seconds or so. You should be able to do bump start and pump run for 25-30 seconds. Just hit start for a split second and return key to on position. Pump run??
Old Feb 10, 2010 | 07:10 PM
coreyb64's Avatar
Yea, i'ma aware thats what its suppose to do but the spirt is more like .2 seconds and i've bumped the starter multiple times with now luck. I think i'ma try to replace the relay underneath the fuse box
Old Feb 10, 2010 | 08:16 PM
nitrousn's Avatar
The simple thing is to check vlotage at the lift pump. Being there is a code is a good sign of a bad connection or a failed lift pump.
OOPS
Sep 27, 2013 11:55 AM
hot rod al
Feb 17, 2011 09:24 PM
firewife
May 29, 2006 03:22 PM
mazeppa
Feb 10, 2004 06:54 PM
