Trans Flush
Old Nov 9, 2006 | 09:52 PM
the496rocket's Avatar
Trans Flush
I need to flush the ATF our of my buddys 01 Cummins Auto, I want to know if I should put Mopar ATF +4 in or go with Mopar ATF+3. The +3 is getting pretty scarce, but I have read it has less friction modifiers and everything in the trans will "grab" better. I only want to go with mopar fluid cause I work at a dodge dealer and I can get it fairly easily.
Old Nov 9, 2006 | 10:32 PM
dieselfan's Avatar
ATF+4 is what is recommended and its what most run.
dieselfan
Old Nov 9, 2006 | 10:39 PM
torquefan's Avatar
I didn't think Dodge even sold +3 anymore.
Old Nov 10, 2006 | 12:32 AM
SMOKNISB's Avatar
ATF +4 is what is recommended. Heck it even says it on the dip stick. ATF +4 meets or exceeds the specs for +3.
Old Nov 10, 2006 | 01:36 AM
Marine's Avatar
Veteran: Marine Corp
Stay with ATF+4.
I know DTT's tranmissions use ATF +3 a few years ago, anyways, when I spoke with Stefan.
Old Nov 10, 2006 | 07:47 AM
yeah, +3 is really hard to get, if fact, I think we only have like a 2 and a half gallons left here, the only reason I asked is cause somewhere I read that +3 will make the trans last longer cause everything will slip less cause of less friction modifiers.
Old Nov 11, 2006 | 08:16 PM
ozzie's Avatar
Atf +4
If you live near a Wal-Mart you can get genuine Mopar fluid for 4.42 per quart.
Old Nov 12, 2006 | 07:55 AM
SMOKNISB's Avatar
I put Valvoline ATF+4 in my new tranny about a month ago. Napa had it on sale for a dollar cheaper than anywhere else. I think it was like 3.4X a quart.
Old Nov 13, 2006 | 05:51 PM
ib516's Avatar
Only use ATF+4 - ATF+3 may cause shudder. TSB here:
http://dodgeram.info/tsb/2006/21-010-06.htm
CACalomino
16
Mar 22, 2010 06:35 PM
Sam Turner2
Nov 18, 2008 10:17 AM
grantx5
Jan 5, 2008 06:56 AM
LFD2037
Nov 8, 2006 09:12 PM
