Starting problems
Starting problems
The engine cranks but won't fire off. If I drain the fuel bowl and then crank the engine it will start but really rough. Fuel pressure is 14 lbs at idle, 9-10 crusing and 6 at WOT under load. Does this sound like the lift pump may be going bad even though pressure is ok?
Matt
Matt
fourthandgoal
88
Dec 27, 2011 05:39 AM
abc4yew
Mar 15, 2007 11:55 PM
