Trans cooler lines leaking, question
Old Nov 20, 2009 | 04:04 PM
tchdodg's Avatar
I've done some searching and am needing clarification. I am chasing leaks on the truck in my sig. It appears the trans cooler lines are leaking up front, where the rubber hose/hard line fittings are. Can I re-seal these in anyway with a new o-ring? Or is it a new line issue? What about just rubber hose and a clamp? Don't want it rigged, just looking for feedback. Thanks.
Old Nov 20, 2009 | 11:55 PM
Russ Roth's Avatar
Rubber line and hose clamps is what a very well respected local shop here suggested to me and what they do. I didn't do that though. I used a cutoff wheel and cut the fitting off and just clamped the original line a couple years ago. Still working.
Old Nov 23, 2009 | 11:15 AM
tchdodg's Avatar
Is there enough play in the rubber hose to just cut the connection out, then slip the old rubber hose over the hard line? I'll take a look after work. That would probably make an easier fix. Thanks.
Old Nov 23, 2009 | 01:22 PM
BIG DOG's Avatar
If you decide to use the trick of clamping the rubber hose over the hard line, check every so often that the hose clamps are tight. I did this and after a couple years the hose blew off and gave my truck a nice transmission fluid undercoating. So i just went ahead and bought the new hoses. Just a suggestion. Good luck.
taneum
Jun 29, 2011 11:46 AM
stange
May 12, 2010 06:36 PM
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
