Leaking trans cooler lines
Old Jun 28, 2011 | 11:21 PM
taneum's Avatar
I noticed I'm leaking trans fluid from the line that comes out of the unit under the turbo. I read this is some type of fluid warmer. Its the rear line at the conection under the rubber hose. So, I read that these can't be fixed, they need to be replaced. If so should I replace the line, or get some fitting and trans hose? I noticed you can find the lines from places other then the dealer for a fair price. Can someone who has had this issue enlighten me on my options.
Old Jun 29, 2011 | 09:48 AM
infidel's Avatar
Remove the line and take it to a place that makes up hydraulic hose to press on the correct fittings.
Much cheaper and longer lasting than OEM lines.
Old Jun 29, 2011 | 10:27 AM
taneum's Avatar
So I can fix the steel line, or are you taking about replacing it?
Old Jun 29, 2011 | 11:46 AM
cj360trider's Avatar
replace the hard lines w a quality flexible line. if you get the right fittings on the flexible lines theyll hook right up. get rid of the hardlines. jus make sure you find a way to leave the temp sensor in the cooler line out of the trans. its a bit important
stange
May 12, 2010 06:36 PM
tchdodg
Nov 23, 2009 01:22 PM
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
