tranny fluid leak fix ... teflon tape?
Old Jun 14, 2005 | 01:43 PM
lglamb's Avatar
traced a tranny fluid leak to the engine-mounted cooler
supply fitting. If a "simple" snug-up doesn't do it, would
it be ok to use some teflon tape on the fitting? Just
wondering what happens if any bits break free in the
system.
Thanks,
Lowell
Old Jun 14, 2005 | 03:08 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I prefer using just enough "Pipe-Dope" to fill the threads.
Old Jun 14, 2005 | 05:31 PM
phox_mulder's Avatar
Mine was leaking around my temperature probe.
Took the probe out and saw the teflon tape that the installer had used had turned into crispy flakes of some white material,
the leak started a couple months after installation.
Cleaned all that out and put a coat of brown RTV on the threads.
Let it sit for a bit, then reassembled, and no leaks as of yet, a couple months later.
phox
Old Jun 14, 2005 | 05:34 PM
dodgenstein's Avatar
Never use Teflon tape on any hydraulic type fitting. It will flake off and clog a small orifice somewhere.
Old Jun 14, 2005 | 06:05 PM
Bocifus's Avatar
Try Permatex® High Performance Thread Sealant.
Casey
Old Jun 14, 2005 | 06:06 PM
Casey
That might be what I used.
I'll have to check the tube.
phox
Old Jun 14, 2005 | 06:17 PM
J BODY's Avatar
If it's the "fitting" that screws into the heat exchanger, yes, you can use sealer on that. If it's the line nut, or a leak from the line flare fitting, NO.
Old Jun 15, 2005 | 08:37 AM
lglamb's Avatar
Thanks, Dodgenstein. That's exactly what I was wondering.
Don't know yet if it's the fitting or the flare. If anyone's attacked
this area, did you have to take off the tire and inner fender
liner to get there, or did a crow's foot wrench work?
Thanks again, everybody.
Lowell
efil4ynot
Sep 9, 2008 11:08 AM
Roperteacher
16
Mar 17, 2008 04:31 PM
Begle1
Jul 14, 2005 03:59 AM
eng208
Jun 6, 2004 05:33 PM
