tranny fluid
tranny fluid
whats the difference between atf+3 and atf+4. book says my truck requires atf+4 but i cant find it at local parts stores. will atf+3 be ok to use or should i bite the bullet and get it at the dealership?
I have a 24V 98.5, and I believe my manual says +3, but not sure. I do know I always put exactly what it says, though. I would think there would be someone besides the dealer that carries the one you need. I don't believe I had to buy any at the dealer.
+4 is, I believe, a semi-synthetic, and is still only available at the dealer. I have always used it in transmissions that call for it, and I don't think I would take a chance using anything else. As someone who works in the trade, I have always been pretty fussy about using the proper fluids for each application, instead of just filling everything up with bulk Dexron like some do.
If it says use ATF4 I believe you need ATF4.
ATF3 users can use ATF4 but you're not supposed to downgrade.
There's supposedly differences in the friction additive package.
The Dealer handles it and AMSOIL advertises their ATF is also ATF4 rated.
you could always just get regualar atf and add a bottle of lube gaurd which will bring it up to spec and save you a lot of money
call the big tranny builders, none of them use atf+4 or +3 for that matter
Valvoline (I believe) makes one that is ATF+4 compliant.
I think it's called Valvoline Extreme ATF or something like that, red bottle, available at most parts stores.
That's what I topped mine off with when I lost 4 quarts sealing up my temp sender leak.
phox
phox
If you want to use the ATF4 like the book says, take a clean 5 gallon bucket to the dealer and have them fill it from their bulk tank. I did that and I THINK i saved around 1.20 a quart. I asked my transmission builder if I should use Synthetic and he said that the atf 4 basically is and there is no reason to change. Everyone has their own opinion though...
Anybody know if the additive is needed in the 01 auto like it is in the older ones???
Kip
Kip
FWIW, I refilled mine (twice) with the Valvoline fluid when
my rubber hoses split (twice) at the front cooler, dumping
basically all the fluid out of the tranny (twice). The TC is
noticeably less Converting on accelleration but still locks
up fine. I can't say whether this additional 'slop' is from
the fluid, or damage from dumping the fluid (twice).
Oh, did I mention this happened twice?
Also, there's a dealer(?) on ebay that sells Mopar +4,
case of 6 gallons for $100. Sometimes a case of 12
quarts for $60 wi shipping. Still expensive, but much
less than walking into a dealer around here ($29/gal).
Lowell
Common
Jun 9, 2008 12:16 PM
Tommy93w350
Jun 26, 2007 04:42 PM
2500
Oct 2, 2006 09:14 PM
icrider
Sep 27, 2006 03:10 PM
