Tranny ?
Old Sep 18, 2006 | 06:56 PM
supercoot69's Avatar
Unhappy Tranny ?
My tranny shifts in and out of OD on the highway w/no load, when the pedal is push a little. Downshifts to fast, then im out of power range. Is that normal? It will do the same in drive shift down 2nd. It also shifts slow into OD . I'm going to try to reset the computer. Anyone have any ideals. Could it be the BDL preasure cyl. Also wondering if you could disconnect the kickdown, or adjust. thanks
99/24v/edge box/k&n/5in exh/BDL Preasure cyl on tranny
Old Sep 18, 2006 | 09:14 PM
scottsjeeprolet's Avatar
Welcome to the site!!!
Try the APPS reset it is explained in the TECH Facts section.
Might wanna call BD and see what they have to say. Mine is doin the goofy 1-2 shift @ lite throttle.
Old Sep 19, 2006 | 02:30 PM
RowJ's Avatar
Originally Posted by supercoot69
My tranny shifts in and out of OD on the highway w/no load, when the pedal is push a little. Is that normal? ... Could it be the BDL preasure cyl.
Not normal at all. My 47RE tranny takes full throttle, at hwy speeds to down shift. Don't know the pressure BD cylinder.
RJ
Old Sep 20, 2006 | 06:02 PM
jimk's Avatar
transmission
RJ
My friend has a transmission that James built that could be close to what you have, no billet shafts in it, he uses full throttle every day or at least every time I see him drive it. I have never seen him power brake it. Just full throttle, hammer down. My poor stock transmission could not take it. Jim
Old Sep 20, 2006 | 06:20 PM
jimk's Avatar
Unhappy transmission
I would not disconnect the kickdown( throttle lever) That is how the transmission knows how much pressure to apply to clutch packs, shift points, ect. I dont remember what the base pressure is at idle, 55 or what ever. Any way if you disconnect the throttle lever on the transmission, your clutches may suffer, along with your pocket book. For what ever it is worth Jim
Old Sep 22, 2006 | 08:22 PM
Thanks for the info. I reset the apps, if seemed to help a little but i'm going to call BD for tranny spec for there product. thanks
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
silverram323
24
Nov 9, 2003 07:48 PM
