Tps replacement
Old Dec 22, 2005 | 10:41 AM
geoff's Avatar
Tps replacement
I am attempting to replace the TPS on my '98.5 ram, but I'm not exactly sure how to test the voltage when I replace it. Is there any way to test the voltage/calibrate the new sensor withought using a scanner?
Reason for replacement is that every now and then(and more often recently) I am getting a dead pedal for about 3-10 seconds followed by a check engine light which had a code for the tps sensor. Mods are DD2's, ez, boost elbow, and full DTT trans.
Old Dec 22, 2005 | 12:08 PM
graphitecumnz's Avatar
shouldn't have to calibrate anything on a 24 valve.
Old Dec 22, 2005 | 09:29 PM
runningbird's Avatar
the manual states that you need a drb scanner and set the tps to a certain voltage at idle and full throttle... any idea's????
Old Dec 22, 2005 | 10:01 PM
piperca's Avatar
I just replaced my APPS (probably what you're replacing) and it didn't need any adjustment. Are you looking at the 12 valve section of the manual, perhaps? Have you looked up APPS in the index ... I think that might be the problem.
Old Dec 23, 2005 | 10:30 AM
zukgod1's Avatar
The new APPS comes "Pre Set" and attached to the bracket. No setting necasary.
dan
whosdunit
May 17, 2014 08:54 AM
DAFF
Dec 12, 2008 11:19 PM
Paradise Racing
Mar 18, 2003 06:26 PM
hvanflee
Mar 13, 2003 03:11 PM
