Torque for the fuel lines
Old Aug 14, 2007 | 09:45 PM
TXaggie09's Avatar
Alright, I heard that its very important to torque the fuel lines at the injectors to the right specs. Question 1: how do you torque something if you cant use a socekt and 2: what is the proper torque
thanks
Old Aug 14, 2007 | 10:22 PM
mini14's Avatar
http://dodgeram.org/tech/dsl/mt_2_fe...specs_isb.html metric crows feet sockets on a torque wrench.
Old Aug 15, 2007 | 10:47 AM
TXaggie09's Avatar
excellent link, thanks man
Old Aug 15, 2007 | 01:05 PM
TXaggie09's Avatar
quick question, does the crows foot socket throw off the torque readings on the torque wrench? It seems like it would give a lower reading due to added leverage.
Old Aug 15, 2007 | 02:58 PM
65pacecar's Avatar
It will vary if you use an adapter on a traditional torque wrench. If you use a torque wrench designed for the crows foot it will be perfect.
Old Aug 15, 2007 | 03:11 PM
TXaggie09's Avatar
ah, i didnt know there was such a thing, im used to the regular torque wrench. Thanks
Old Aug 15, 2007 | 03:17 PM
65pacecar's Avatar
The Regular will get you close enough in the torque range that I wouldn’t worry about it, unless you have other uses for the crows foot kind. We happen to have calibrated torque wrenches of both styles where I work, so if I need a crows foot I can sign it out for the day, otherwise I use the regular one at home. The expense for a one time use or very limited usage would probably not be worth it.
Old Aug 15, 2007 | 09:22 PM
mini14's Avatar
http://www.norbar.com/torquewrenchex...calculator.php this might help
Old Aug 15, 2007 | 10:35 PM
TXaggie09's Avatar
thanks, i found that link earlier along with a little more complicated equation, either way I should be able to get it close enough. Thanks for all the input
Old Aug 16, 2007 | 12:28 AM
smiller4597's Avatar
mini14, great links! Thank you!
Old Aug 16, 2007 | 10:17 AM
PaulDaisy's Avatar
My aircraft mechanics tell me that if you install crawfoot along the torque wrench, the torque is chenged (very little mind you). If you install crewofoot at 90* to the wrench, there torque reading will be accurate.
-P
Old Aug 16, 2007 | 10:22 PM
mini14's Avatar
u all r welcome.
piperca
Mar 12, 2006 07:49 PM
chucktownsend5
Mar 8, 2005 08:21 PM
MrKen
Feb 25, 2005 04:22 AM
debolton
24
Jun 29, 2004 09:22 PM
hellotbone
Sep 1, 2003 08:46 PM
