tires
Old Aug 29, 2011 | 07:01 PM
southerman's Avatar
tires
what would cause my front tires to wear on the sides passenger side worse than drivers and noticed rear tires wearing in the middle?
Old Aug 29, 2011 | 07:20 PM
maxwellp's Avatar
Talking
Inside? outside? Front
Center Rear / too much air psi
Old Aug 29, 2011 | 07:33 PM
southerman's Avatar
outside on the front passenger side worse rear in the middle passenger side also worse.
Old Aug 29, 2011 | 07:52 PM
maxwellp's Avatar
As far as the rear, the passenger side tire is the drive tire. It will be the baldest. Center wear is from too high psi.
If only the front passenger is wearing on the out side it has to much positive camber.
Old Aug 29, 2011 | 07:54 PM
southerman's Avatar
yea psi is good just a couple lbs. low i guess i will get a front end alignment. thanks
Old Aug 30, 2011 | 06:37 PM
nitrousn's Avatar
You might have tires starting to seperate.
chrisminx
14
Jul 7, 2010 06:48 PM
1320
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
Captain
Sep 9, 2005 12:16 AM
