Timing
Old Apr 8, 2019 | 08:03 AM
Adam17238's Avatar
Timing
So I have what may be a dumb question. Can you advance the timing manually on a vp44 by turning it forward a tooth. Now I know it's timed electronically but I'm a big truck guy and on the big cats this can be done and it makes a huge difference in power.
Old Apr 8, 2019 | 10:20 AM
AlpineRAM's Avatar
You should not do this, it will set codes because the crankshaft position sensor and the pump will disagree on the timing.
To change the timing you need to get either a tuner (eg Smarty) or a box (eg Edge Comp)-
both of them will give you the option of adjusted timing and adding fuel.
GR40RCapri
Jul 24, 2006 11:47 PM
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
redhornet
May 28, 2004 06:06 PM
