Time to update your truck maintenance log
Old Mar 30, 2006 | 09:00 AM
Dieseldude4x4's Avatar
Bought the truck brand new in January of 1999 with seven miles on it at Williamsburg Dodge, $32000.
Went through four lift pumps in 145000 miles, $150 a piece.
Working on the third set of Michelins now, getting 75 to 80000 miles per set, $1200 per set of six.
Put the Jacobs on at about 20000 miles, $850, still on the original pads and shoes all around at 170000 miles and still over half there.
Put $11000 in the engine about two years ago, burnt up number six piston, my stupid fault (cam, pistons, fire rings, studs, blue chip, turbo, etc,etc).
New SBC and Fass two years ago plus a four inch down pipe and DDII's, $4300.
Complete stereo replacement, Panasonic deck, two Crossfire amps (400 & 300 watt), 10 inch DVC on the back seat, eight disc CD changer, $2400.
Third set of batteries is about to go out, $89 a piece at NAPA.
AMSOIL dual remote system, $315.
Transcoolers, about $200 if I remember right.
Mag Hytec rear end cover, $137 if I remember right.
Stacks about four years ago, about $450 if I remember right.
All kinds of aluminum junk hanging on, about $540 if I rememebr right.
GN hidden hitch, $520 installed.
Other than the elective stuff (stereo, etc), and the stupid stuff (burning up number 6), the truck has performed pretty much flawless and done everything I ever asked it to. Even pulling tractors through Iowa when the outside air temp was near 110 degrees. I'll take good old American iron any day.
Old Mar 30, 2006 | 10:44 AM
HOHN's Avatar
$4300 for a clutch, FASS, and 4"dp???
That better have been one heck of a SBC quadruple disc monster.
My math shows FASS is $600, DP is $200, and SBC DD is $1800
Did you get charged $1700 to install $2600 of stuff?
I'm starting to realize just how much of a cheapskate I really am
Old Mar 30, 2006 | 10:58 AM
signature600's Avatar
I'm not even going to list my stuff, but the only things that have actually failed are brake pads and shoes (), stock turbo (another ), 1 starter. 1 alternator, A/C Compressor clutch, and a carrier bearing. Oh, and 2 stock clutches
Everything else wasn't really needed, but a lot of fun At one time I had over $9K in different turbos/twin sets, all at the same time!! I've worked it down to a measly $6800 in turbos
Anyone need a turbo(s)??
Chris
Old Mar 30, 2006 | 03:07 PM
high country's Avatar
I lost EVERY SINGLE u joint within 500 miles of each other, on the 3rd one I said heck with it I am doing all of them now......good thing.
Old Mar 30, 2006 | 06:03 PM
You forgot to add the DDII's and the KDP, and a few other things while I was there too.
Old Mar 30, 2006 | 10:49 PM
BigBlue's Avatar
The only broken parts I've had are a hub, power steering box(my fault), track bar (my fault), and an ac compressor. I'm not counting the 2 lift pumps cause that's a given. Still on my original VP. Saturday I'm doing my oil and filter. Only 2000 more miles to go before I hit 100,000.
Old Mar 31, 2006 | 11:55 AM
johnh's Avatar
i think you were over charged for your batt`s. i priced them at napa in west jordan,they were less than 70.00 ea (group 27)
Old Mar 31, 2006 | 12:07 PM
Willy91's Avatar
My trucks had, all U-joints replaced and the Hx-35, and tranny...well that's a given, over all a very reliable truck, I just bought it from my grandpa and in 2500 miles it will hit 45000 total miles.
Old Mar 31, 2006 | 12:37 PM
Abbynormal's Avatar
My'96 with 136,000 miles, GoodYear paid for a new rear fender after their OE tire peeled off the tread (like a recap on a big rig) and TORE UP my fender bad !
New fuel line,
new radiator barely in time under warranty ,
new headlight switch,
New radio (again under warranty ) . Coffee spilt on it cuz of the dumb place they put cup holder ! I was just proud Mr Chrysler fixed it for me. See they are not all stealers !
New rotors at about 130k man I need a jake brake !
and on my 3rd set of tires and shoes.
Not too bad all in all !
Old Mar 31, 2006 | 01:06 PM
6WHEELER's Avatar
lets see, bought truck with new motor and turbo(cost him 10,000for that) with 27miles on it from a buddy,
1 yr later SBC and ATS 5speed $4700 installed and lift pump failure,replaced with FASS $539
install posi lok rear diff $500, tired of getting stuck with open diff
dual shocks and stablizers $400
1 yr later VP44, $1500 replaced with HRVP, warrenty then replaced with HRVP again.
B&W gooseneck hitch $239
everything else was a want not a need and to much to add up in my head right now, alpine, 10in subs, nerf bars, full exhaust w\stacks, etc etc
Old Mar 31, 2006 | 01:16 PM
Haulin_in_Dixie's Avatar
How are U joints a given?? My truck has right at 360,000 on the original U joints, roters and drums.
Old Mar 31, 2006 | 01:48 PM
You're just special
I put U-joints in mine at 265 when I had the driveshaft shortened for the NV5600 Rotors at 225K, and they were SHOT!!!! I could see the fins through the side (they never felt funny, just squeaked)
Chris
Old Mar 31, 2006 | 08:56 PM
dodgeguy71's Avatar
2002 Dodge 2500 4x4 diesel, $21,695(plus interest), 4 new firestones to replace the like new lightweight Kelly Safari's, $480, new front pads, week after I bought it...$55...done at work, guy at work clean and pro poly truck, $30......passing gassers uphill while towing a load.....priceless!
And I have not even spent any money on fun stuff yet...like FASS, exhaust, gauges....you guys are so lucky!!
06RAM2500
Nov 12, 2011 08:43 PM
Greguw
Nov 2, 2009 05:36 PM
VictorC
Jan 2, 2009 11:52 PM
bigragu
Jan 12, 2006 04:57 PM
