time to let the turbo cool down?
Old Dec 31, 2003 | 02:43 PM
Cruzer75's Avatar
Ok how long should i let the truck run at idle before i shut her down in order for the turbo to cool down? Minute? 2? 3? 5? Thanks.
Stew
Old Dec 31, 2003 | 03:01 PM
Fishin2Deep4U's Avatar
The answer is....... yes.
The generally accepted rule is 300 degrees. Now that will vary depending on outside air temp, how hard you were running the truck and the load.
Usually, under slow and go circumstances, 1-2 minutes.
medium load or flat highway driving, 3-4 minutes
heavy load and or mountainous driving, 5+ minutes.
Clear as mud?
These times are from my own observations, I am sure others have a different idea on times. I would put in a pyro gauge and use it for the anwer to your question.
Dave
Old Dec 31, 2003 | 05:22 PM
jigdog's Avatar
Talking
cruzer i usually let mine cool about 1 min for around town and i watch the pyro.
Old Dec 31, 2003 | 05:25 PM
infidel's Avatar
Question: I tow a trailer during the summer. Is there any special cooldown needed?
Cummins : If you are towing heavy loads this summer, you should let the engine idle for a three- to five-minute cooldown after extended full-throttle or high-power operation. However, under normal driving conditions like simply exiting a highway, a cooldown isn’t needed.
http://list.priceweber.com/cummins/summer.html
Old Dec 31, 2003 | 06:16 PM
y-knot's Avatar
Rodger that, it depends on what you were doing before with the truck. If you need explaination, next time you tow, sit in the truck and watch the pyro till it is at 300, that is the time it takes. And if you are just dodle dicking around town, watch and see how long that takes.
Old Jan 1, 2004 | 07:21 PM
PapaSmurf's Avatar
Hello
My truck cools down pretty fast, but I still let it idle for at least a couple of minutes after I stop the truck.
When we are pulling something I let her idle for roughly 5 minutes to let everything cool down nice and slow. I let it idle while we do things like get our shoes back on and time for me to open the door and stand outside and stretch.
See Ya
Chris
Old Jan 1, 2004 | 07:26 PM
thumper 549's Avatar
everybody togather now say 300 deg. (mabe 315) you need a guage and you need to think what the oil has been doing too!!
Old Jan 1, 2004 | 08:41 PM
y-knot's Avatar
Well that is the nice thing about the cool down timer, just set and leave. Not only does it help remind me to cool things down, it makes it simple and very easy. I use the lowest setting 95% of the time, and it is more then enough. In the heat of summer and while towing, I would just got to the longest setting. So simple, and so in-expensive, I don't know why more people have not seen the light? I love the feature.
Old Jan 1, 2004 | 09:09 PM
Bearfoot2's Avatar
Cruzer75,
You don't have anything in your signature to let us know what you have for mods.
If you are running a stock truck don't even worry about cool down unless you've been running hard or pulling. Then 2 minutes are plenty.
Stan
Old Jan 4, 2004 | 11:00 AM
Cruzer75's Avatar
ok updated it!
Ok updated my signiture line! Truck is a Stock 99 2500 CTD, 5spd, quad cab, 8ft bed. I am going to get the 3pillar gauges first, EGT, Boost, and Fuel Pressure. Now everybody says "whatch the pyro gauge" Do they mean an EGT OR do they mean a specific other thermocouple place in the oil flow for the turbo?
Stew
Old Jan 4, 2004 | 11:16 AM
MLR1's Avatar
Everyone is referring to the EGT.
Old Jan 7, 2004 | 10:15 AM
rattle_rattle's Avatar
I have my Isspro turbo temperature monitor set to 275.
wrangler04
15
Jul 23, 2007 03:36 PM
Hoss
Dec 10, 2005 02:30 AM
Flatty
15
Dec 8, 2004 04:18 PM
Varmint
Mar 26, 2004 10:40 PM
