Throttle problem
Old Mar 7, 2005 | 05:14 PM
caleb c.'s Avatar
Throttle problem
I just got a '02 with the H.O. engine and there is a weird problem I was wondering about.I still have a little waranty left so I want to figure it out.Anyway,when you shift gears and then give it some throttle it wont do anything,no acceleration and then a few seconds later it kicks in and it pulls hard.It does not do this all the time but it is pretty often.One guy told me it might be the potentiometer (tps).Any ideas?Thanks
Old Mar 7, 2005 | 06:00 PM
dieselrob's Avatar
thats could be it. you need a fuel presure guage on the thing. you could have a bad lift pump and possible vp44 crapin out. theres a port on your vp where you can check presure with a maunul guage.
Old Mar 7, 2005 | 11:12 PM
caleb c.'s Avatar
Any other ideas?
Old Mar 7, 2005 | 11:16 PM
phox_mulder's Avatar
Here's the reset procedure for the APPS (newfangled TPS found in the 24 valve trucks)
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Worth a shot, won't hurt anything, and only costs a few minutes of your time,
with a big beer break in the middle.
phox
Old Mar 8, 2005 | 02:14 PM
BillH's Avatar
Had the same problem, turned out to be the VP. The dealer just put another one on yesterday, all is ok now.
Old Mar 8, 2005 | 03:53 PM
caleb c.'s Avatar
Well I just did the apps thing that phox recomended and now it is smoking white. Any ideas on that?
Old Mar 8, 2005 | 03:58 PM
tool's Avatar
Sounds like your VP may be dying. Have you checked the codes?
Old Mar 8, 2005 | 04:27 PM
White smoke after warmup is most likely due to slipped timing.
Timing isn't adjustable in the VP44 (well, electronically it is), so I'd say your injection pump is dead or dying.
phox
Old Mar 8, 2005 | 05:52 PM
caleb c.'s Avatar
It is only smoking when it is cold.It goes away when it gets warm.And it started today right after I did the APPS adjustment. So,I don't really know whats up.It only has 49k on it.
Old Mar 8, 2005 | 05:56 PM
How cold is cold?
I only see the white smoke when it's down around freezing or colder.
phox
Old Mar 8, 2005 | 06:02 PM
caleb c.'s Avatar
It has been up to 80 today.And it was only off for about a hour.So really its not cold at all,just the coolant temp isn't up yet.It wasn't doing this before I made the adjustment.So maybe it backfired on me! So anyway,I will be taking it to the dealer I got it from and have them check it out in a day or so.
Onemoparnut
Aug 19, 2013 08:11 PM
Mallard
Apr 9, 2007 12:59 AM
dieselcrazy
Oct 1, 2003 08:55 AM
christinyou
Feb 7, 2003 09:32 AM
Burgher
Jan 11, 2003 05:05 PM
