Are these the tranny lines i need??
Old Mar 20, 2008 | 11:40 PM
Fullsizeyota's Avatar
You know the drill....... The factory hard lines that supply the oil cooler and the tranny suck. Mine wore a hole through the line. Now its leaking off the heat exchanger. I need to fix this and forget i ever had this problem
are the top two lines in this link the ones that i need? they LOOK like it, but they are very small and it's hard to see. My 21 year old eyes dont work like they used to
http://www.rockauto.com/catalog/raca...parttype=10343
If so, I'm ordering them as soon as someone can confirm that these are infact the lines.
Thanks
Edit, I need the lines that come off the heat exchanger, run under the TC housing, and up along the driver side of the engine and tie into the rubber line thats directly connected to the oil cooler. I need the other line that also runs from the tranny, drivers side, right by the shift linkage and also goes to the rubber oil cooler line.
Old Mar 21, 2008 | 11:57 AM
91rangerturbo's Avatar
My lines started leaking. So i cut them where it wasn't leaking and removed the section that was bad. And installed a 1/2 ID fuel hose and it works fine for the 4 weeks it has been on there. But i am looking for a more permant replacement too when i install a new built tranny.
Mine lines leaked right were it bends coming under the tranny from side to side. Or drivers door to passenger door if that makes sense.. None of those lines look like it is it. But i could be wrong.
Jasonbailey
Oct 23, 2011 11:35 AM
bway1341
Sep 20, 2011 05:44 PM
D384D
14
Oct 26, 2010 10:23 AM
MrKen
Feb 25, 2005 04:22 AM
hellotbone
Sep 1, 2003 08:46 PM
