Thermostat
Old Feb 29, 2012 | 03:51 PM
betsycam's Avatar
Thermostat
My check gauges light flicked on and off a couple of times when I started up today, then went off. I noticed the engine temp gauge was dead - below 140 and not moving at all. I had noticed that my fuel economy was sucking on recent rides. There's a Cummins not to far away so I'll get the actual Cummins thermostat, not an aftermarket as I read they aren't good.
Anyplace I can find instructions/pictures for replacement?
1999 2500 QC 4x4
Old Feb 29, 2012 | 05:57 PM
Midnite's Avatar
The thermostat is right under where the upper radiator hose attaches to the cylinder head. It's two 10mm bolts I think. Hopefully someone will correct me if I'm wrong, because all this is off the top of my head.
Changing the thermostat won't do anything about the check engine light though. It's only going to help your engine get up to operating temperature. You might want to see if you can see if any codes have been set.
Old Feb 29, 2012 | 09:19 PM
betsycam's Avatar
I will check for codes since I have a reader, but it has done this before without the thermostat issue. I wondered if it was because on cold days the oil pressure is too high until it warms up? That might be lame-**** logic!
Thanks for the location/mounting tip.
Old Feb 29, 2012 | 09:26 PM
davemac's Avatar
Try this:
http://www.dodgeram.org/tech/dsl/coo...thermostat.htm
Old Feb 29, 2012 | 10:37 PM
SIXSLUG's Avatar
Just make sure you get the new one in right side up and don't over torque the two bolts. Just snug 'em up and check them a couple days after driving it up to temp.
Old Mar 9, 2012 | 04:18 PM
klcammie's Avatar
davmac great link for t-stat.
Old Mar 9, 2012 | 07:39 PM
rickf's Avatar
The O/P was talking about the check GAUGES light not the check ENGINE light.
Rick
Bookshelf
May 30, 2009 01:17 AM
mechanic
Mar 25, 2003 08:45 AM
BigBlue
Dec 10, 2002 10:55 AM
Crazy Horse
Nov 16, 2002 01:00 AM
dart racer
Nov 11, 2002 10:10 AM
