is there a way to force a 47re to hold overdrive
Old Mar 31, 2006 | 02:55 PM
Wolf_fighter's Avatar
is there a way to make overdrive hold until the OD off switch is pushed or another switch have a few guys running 00 and 01 rams with built trannies and getting sick of overdriving kicking out premanutrely
Old Mar 31, 2006 | 03:06 PM
Mike D's Avatar
Search mystery switch.
Old Mar 31, 2006 | 03:39 PM
Mechanos's Avatar
That's for the converter lockup clutch.... not the OD.
Old Mar 31, 2006 | 04:00 PM
Mcmopar's Avatar
If your slick you can do both, same principal.
Old Mar 31, 2006 | 08:14 PM
Mike D's Avatar
If you say so... I know my switch will hold overdrive until the cows come home. Right Phil! It's just a simple matter of cutting the wire. and using the right switch.
https://www.dieseltruckresource.com/...cat=500&page=2
Old Mar 31, 2006 | 08:37 PM
MikeR's Avatar
I have a mystery switch on mine....I use it for dyno runs and 1/4mi track runs.
Yes, the switch wired in is for TCC lockup, but it will also stay in OD without downshifting. It was once quickly explained it me years ago, let's see if I can remember it right.
With the switch thrown, and the signal is then fully gounded, the tranny signal in the PCM then thinks the truck is doing maximum speed so it's not going to let it downshift even when the kickdown cable is fully pulled.
Old Mar 31, 2006 | 08:54 PM
Mike D's Avatar
MikeR, I think he was trying to see if he could get it to say in over-drive, not lock up. That's what my post was about.
skyking1
May 19, 2012 11:27 PM
72demon440
Apr 27, 2007 10:45 PM
robert78.5
Jan 22, 2007 07:24 AM
Usta HaveA Hemi
Aug 24, 2005 01:10 AM
