testing for boost leaks
Old Jun 8, 2006 | 07:19 PM
chadwick's Avatar
ok guys i have read a couple threads on here about this subject. i just wanted to ask what the best way to test the intake system for leaks. my problem that is my truck feels sluggesh and i hear a big whoosh sound when i get on the throttle.
Old Jun 8, 2006 | 10:44 PM
WUnderwood's Avatar
the way I did it on my Ford was fab up a rubber coupler with a PVC plug on the end, with an adapter for an air hose(Home Depot or Lowes) and attach it to your intake side of the turbo (the same side as you attach your air filter), and slowly add air pressure until you hear air wooshing. spray soapy water around your turbo and boots. I used a portable air pump for my air, because I dont have access to shop air. PM me if you need any more details. here's a pic:
hope this helps
Old Jun 8, 2006 | 11:07 PM
J BODY's Avatar
picts of mine in my gallery. Mine uses shop air. I just use the regulator mounted on it to adjust the psi to the air inlet.
Old Jun 9, 2006 | 09:17 AM
HiJenks's Avatar
I had the same problem with boost leak, max boost of 11# at 2500rpm, this at 8Pm travelled 800mi that way. I made my adapter at Home Depot in Kileen TX. from a 4" PVC cap, a rubber 4" coupler, two hose clamps and used a step drill to thread the air coupler in to the cap, cost about $15. I added pics in my gallery.
abchoppers
Jan 26, 2011 05:38 AM
2500CTD
Sep 5, 2006 02:32 PM
bigragu
Mar 12, 2006 07:01 AM
thumbs
Jun 28, 2004 10:42 PM
thumbs
Oct 22, 2003 01:02 AM
