Testing IC for leaks
I've only tested one intercooler for leaks, and I took it to a local radiator shop where they had the setup for it. I don't know exactly how they do it, so I can't really help ya there.. If someone on here doesnt have any ideas or comments, I suggest calling your local radiator shops and seeing if they can do it.
Have you removed & inspected all of the rubber couplers on the piping? As well as inspected the intercooler piping for leaks from holes worn into the piping or??
Nope I am just starting to try to see if I have a problem with the thing. I think I may because of the low boost.
I think I can get some pvs end caps and cap both ends of the pipeing, install a pressure gauge and air fitting and I should be good. I would just like to see a setup first.
Did you get my message about the speedometer
bigragu
Mar 12, 2006 07:01 AM
