Switch to Redline/AMS?
Old Feb 10, 2004 | 02:23 PM
Eagle Driver's Avatar
Question Switch to Redline/AMS?
Ok, the truck has only 600 miles on it. I want to change the tranny and diff's to Redline synthetic (same weight/viscos) because I've had good experiences with that brand. This being the first new vehicle I've owned, I'm wondering about the break in period for the tranny and diff's. What kind of mileage would you guys recommend for switching the lube the first time. I don't want to have to replace it again anytime soon, so I'd like to let it break in so I can change it once to Redline and call it done. Any ideas on fluid quanity, or where I find out which diff's I have (Dana, etc)? I should point out that I have no intention of switching the engine to synthetic yet, just the diff's and 6 spd tranny.
Old Feb 10, 2004 | 10:46 PM
Tartarus's Avatar
The 5600's throw out a lot of metallic particles during the first few thousand miles they're run. Sensitive synchros, too. I'd change out the oil around 5000 miles, 20K miles, and then every 30K miles afterward. You can stick to the warranty oil, or use a better synthetic product like Redline MTL, at your discretion.
You should have American diffs/axles instead of Danas, which are in the 2nd generation CTD's. Actually, you ought to post this in the 3rd generation forum -- those guys could help you more.
Old Feb 11, 2004 | 08:50 AM
rossn2's Avatar
You and I have the same vehicle, according to your post.
I changed everything out between 6800-7100 miles.
If you pm me I'll send you a spread sheet I've put together on MOPAR/AMSOIL/FLEETGUARD/TRUFLOW/REDLINE numbers, products with Quantities and costs (from on-line places)
May help...
Old Feb 11, 2004 | 10:39 AM
04ctd's Avatar
Pls post the AMSOIL numbers, a buddy is a dealer, just need to know what to tell him & to order, and quantity.
Old Feb 11, 2004 | 11:11 AM
rossn2's Avatar
DODGE 2004 2500 Quad Cab, 4x4, 3.73 rear, 6spd manual, HO Cummins ISB 305)
Engine Oil (11 Qts) MOPAR 15-40w AMSOIL 15-40W Diesel Marine or Series 3000 5-30w
Oil Filter (1 Qt) Mopar 05083285AA, AMSOIL SDF-80, FLEETGUARD LF-3972 or Stratapore LF 16035
Air Filter Mopar AF53032700AA, AMSOIL TS 189 Foam, TrueFlow 30200
Transfer Case (up to 5 pts/3 qts) Mopar ATF +4 , AMSOIL Synthetic Universal Automatic
Man Trans NV 5600 (up to 9.5 pts/5qts) Mopar 4874464, AMSOIL Engine oil Series 3000 5-30w, REDLINE MTL
Frt & Rear Axle ( 5pts frt/8pts rear/8qts total) Mopar GL-5 75w-90, AMSOIL Series 2000 75-90w or 75-140w(rear only if alot of towing), REDLINE 75w90-Gear Oil
Engine Fuel Filter' MOPAR 5015581AB, AMSOIL FF 1093, FleetGuard FS 19579
GENO's COMBO PACK 4 LF 16035 Stratapore and 2 FS 19579 Filters for $58.00 (Change Oil filter at 7500, oil/filter 15000, filter 22500, oil/filter 30k and Fuel Filter at 15/30K)
Links as follows: AND I DON"T WORK FOR ANY OF THESE!
AMSOIL: http://www.amsoil.com/products.htm
GENOS Garage: http://www.genosgarage.com/
REDLINE: http://www.myoilshop.com/AutoPrds.html
TRUEFLOW: http://www.midwestspecialtyproducts....s/trueflow.htm
Man do I have finger cramp now! ON ALL OIL CAPACITIES I ORDERED 1 EXTRA just in case, example 5qts for manual trans, ordered 6 quarts...ENGINE OIL I ORDERED 4 GALLONS, That way I have an extra Gallon for Oil Filter change at 7500 miles and any extra needed. Hope this helps...You can go to the AMSOIL site for capacities on all vehicles too.
Old Feb 11, 2004 | 04:18 PM
04ctd's Avatar
sweet!! that's definitely a cut & paste into my "ram stuff" word document.
tks for all that info
Old Feb 12, 2004 | 12:15 PM
HOHN's Avatar
The diffs are safe to change with less than 1K miles. The Redline gear oils are IMHO the best on the market.
The Redline MTL is the stuff to use in the 5600. DO NOT USE ENGINE OIL-- Amsoil or anyone else's. Those synchros need a little friction to operate, and the MTL is specifically designed for this application (manual transmissions that need a thinner lube)
I am a big believer in the Redline products being fantastic. The only real debate concerning them in my mind is whether or not they are worth the money, not whether or not they are great.
I would Redline the whole driveline, except perhaps the engine. That's the only area where I am not convinced of the RL cost effectiveness.
For the Record, I HAVE used the RL 15w-40 engine oil. It was fantastic-- 1.5 more mpg, 2psi more boost, engine was a LOT quieter.
But it's hard to argue ANY oil is worth $30 a gallon!!!! I now use Delo. I may go back to the Redline, even at the ridiculous price. I was really impressed with it, though I haven't a shred of UOA or any scientific "proof" that it's better-- just my experience and observations.
YMMV
Justin
Old Feb 12, 2004 | 03:37 PM
rossn2's Avatar
Concur, I'm running MTL in the transmission and AMSOIL in everything else. I was just putting out the different part numbers I collected when making my decision on which synthetic to use where...
Old Feb 15, 2004 | 12:23 AM
Chip's Avatar
Hey Eagle driver,
Your diffs are AAM's which stands for American Axle Manufactoring, not sure about thelubes that the manufactor calls for, I use Amsoil in everything but the tranny, I use Redline MT-90 there. The latest issue of Four Wheeler mag has a really good comparison on the Dana axles and the AAM axles. Dodge went to using the AAM axles in the '03 model heavy duty trucks.
Chip
Old Feb 15, 2004 | 10:12 AM
ok, thanks for that. The guy from redline said i would have to figure out if they were the 12 inch (??, i think) or the dana, so i guess since it's not the dana, by process of elimination.... I think I'll wait till about 2k miles before I switch everything (minus the engine) to full synthetic.
Old Feb 16, 2004 | 01:49 PM
rossn2's Avatar
Look in your Glove Box, sticker tells everything....
Old Feb 16, 2004 | 02:34 PM
DF5152's Avatar
aam axles come for the factory with synthetic fill. be very carfull what lube you us in the standard trany there have been many post leading to syncros going bad from improper fluid. there have also been recent warantee issues about people not using mopar recomended lubes.
Old Feb 16, 2004 | 02:49 PM
rossn2's Avatar
I would like to read the posts and recent warantee issues...
please provide a link
BTW food for thought - REDLINE 15w-40 Diesel Oil is not "CI" rated yet. I know I'm going to open a can of worms on that one....
Old Feb 16, 2004 | 05:50 PM
DF5152's Avatar
Originally posted by rossn2
[B
[/B]
did a quick search and couldnt find it it specifically dealt with someone warrantee claim and sythetic fill use in his transmission. I believe it even went to court and he was denied based an older TSB that chrysler has designating specific fluids for specific aplications...
Dan
Old Feb 17, 2004 | 08:52 AM
HOHN's Avatar
[B]
No can here, since my 02 only requires CH-4. You 3rd gen guys might want to reconsider. I don't think I would use an oil not rated CI-4 in a 3rd gen.
That said, I think that RL just hasn't updated the specs yet to CI-4. I would be pretty surprised if it didn't already surpass those specs by quite a bit.
Justin
CumminsRedneck
Oct 13, 2014 04:49 AM
walt_mink
16
Oct 28, 2008 02:35 PM
rogerL1961
Jul 19, 2007 06:43 PM
treadway47025
May 8, 2007 12:23 PM
DODGE4X4
Feb 4, 2005 02:58 AM
