Strange whine/hissing??
My truck has recently developed a strange whining/hissing noise under the cab. If I had to guess, I'd say near the trans x-member.
It does it while rolling and quits when the truck stops. I've tried hanging my head out the door while rolling and can't at all pin point it.
I've also tried hitting the brakes, pushing in the clutch, putting it in nuetral, turning the steering wheel, deccelerating, accelerating, turning the key off and coasting, putting it in 4wd, and just about everything else to either stop or change the sound and nothing works. Only stopping makes it quit and that makes it hard to figure out.
Any advice? I tried searching and found nothing conclusive.
Oh yeah, when it first starts, it does this stuttering bit like off on off on and then just goes solid until the truck stops.
I looked at vacuum lines, ujoints, seals, checked fluid levels, and everything looks ok.
When this first started about two weeks ago, it was more of a quiet hiss, now it's a louder whining.
It is definitely not turbo or alternator related.
The throwout bearing would whine or make noise anytime the engine is running the flywheel is turning. Get a brave volenteer to lay under the truck as you drive forward.
Let us know what you find, good luck.
carrier bearing in the driveshaft...only part that is ALWAYS moving when the trucks is moving whether in gear out of gear, 4x4 2x4
my old man had one go bad on his old 95 and it made the same noise
Carrier bearing would be a great guess but my short bed QuadCab is not so equipped.
It still makes the noise with the engine off, in neutral, coasting, at which point the flywheel, clutch, t/o bearing, and pilot bearing should all be sitting still.
Thanks guy's, keep the suggestions coming.
Hummin Cummins
14
05-24-2003 01:20 AM
