Strange Sound
Strange Sound
Hi All;
New to this board and relatively new to CTD's. Had my 2001.5 for about a year now but put it up for the winter and just resumed driving it a few weeks ago. Had fuel stabilizer in it all winter and started it up & ran it up to 190* once a week. Idles fine, runs just like it did last fall but it seems like when I'm pulling a hill and working it a little, I get this pulsating noise from the engine. I don't know how to better describe it . The truck 's speed doesn't seem to pulsate along with the noise. Only noticable, like I said, when the engine is under load. Didn't get any codes by switching on the ignition 3 times. Just got a fuel pressure guage but not yet hooked up.
One more thing, how does one figure out when the 5 year warranty expires? Truck only has 56k on it. Any help appreciated and sorry I can't give a better description of the problem. Thanks.
Your warranty should still be good and I think it is 10 year 100k. It sounds like a fuel problem to me, take out any fuel box you might have and go to Dodge. If you have a fuel box you might try taking it out and see how it runs.
P.S. Welcome to the site.
you don't think it is your fan clutch kicking in.....
I was puzzled the first time I had mine kick in.
It was going up a long grade with a load and then this noise came ....then went away....then came on,......then went away.
I noticed it coincided with the temp gauge...then realized it was the fan clutch kicking in.
Thanks for the replies.
The pulsations are about one second apart, I don't think it's the fan clutch. Will have to get the gauge hooked up and see what it says. How do I figure out what my in service date is? Thanks again.
Thats the day the truck was originally purchased and titled to the first owner. Also theres a TSB about the thermostat. Says that when pulling a grade and getting a thumping noise to change to a differant themostat. You can check on dieselram.org for all tsb's on truck. This should be a warrenty item if you are still under 100k.
http://dodgeram.info/tsb/2002/09-008-02.htm
Valv
Apr 11, 2005 06:01 AM
thefb
Sep 21, 2004 11:29 AM
