Strange little Buckaroo
Old Aug 12, 2003 | 10:54 AM
dcwm's Avatar
It's happened maybe 12 times now and I'm really not sure yet if it's transmission or engine.
When starting out from a dead stop the truck will begin a little bucking routine as it shifts from 1rst to 2nd. The engine also "hunts" up and down during this time. Now, the engine bucking could be caused from the tranny shifting back and forth between 1rst and 2nd OR the Tranny could be shifting or "hunting" due to the engine surging. I'm just not sure at this point.
Changed Fluid and adjusted bands about 4K miles ago.
I know this isn't much to go on but am hoping someone recognizes this as something specific.
Thanks a Million for any help, this is really worrying me.
Old Aug 12, 2003 | 11:24 AM
Bearfoot2's Avatar
Re:Strange little Buckaroo
Mines been "hunting" between 1 & 2 ever since I bought it with 44k on it. Only does it when going about 3 or 4 mph, like in a parking lot (or my driveway). I've been told that one of the solenoids in the tranny is bad and causes that.
HTH Stan
Old Aug 13, 2003 | 09:31 AM
Diesel Dave's Avatar
Try the APPS reset procedure in the tech section of this site and see if that helps. I don't know if that will help, but it is worth a try.
Old Aug 15, 2003 | 11:11 PM
dcwm's Avatar
[quote author=Bearfoot2 link=board=4;threadid=18309;start=0#msg171561 date=1060705468]
HTH Stan
[/quote]
This sounds just like mine, very well put. I'm going to check into this.
Thanks Bearfoot2, this helps to put my mind at ease.
Old Aug 16, 2003 | 09:13 AM
drecu's Avatar
Anyone know which solinoid? cause my truck used to do this before I had tsb 18-02-99 done & now it shifts way better just the 2-3 shift is 30mph wot. & i do not like it, but I have been having a few problems so I was wondering if anyone knew what solinoid is bad??
DRecu!
Old Aug 16, 2003 | 04:27 PM
AlpineRAM's Avatar
DRECU:
For the 2-3 shift it should be the governor solenoid.
It could also be the governor pressure sensor.
BUT- the 2-3 shiftpoint is not the one discussed above- did you check your TV cable setting?
HTH
AlpineRAM
Hopalong
Dec 10, 2008 03:14 AM
Mexstan
Sep 16, 2006 05:29 PM
JW3
Mar 15, 2006 08:23 PM
BIGHEAD
Nov 26, 2005 08:51 PM
