Stock Lift Pump Pressure, What's Good??
Old Jul 27, 2006 | 04:45 PM
xmr's Avatar
xmr
I have heard that you really don't want to get below 8 the other pressures sound normal. I would change the fuel filter and see what the readings are.
I have the vulcan bigline relocate kit and mine are 14-15 at ldle, 12 to 13 at 70 mph and 11 at wot.
Old Jul 27, 2006 | 07:48 PM
nitrousn's Avatar
Fill out your sig so we know what kind of truck you have.
My 2002 with 77 grand has about the same readings. Mine has been that way since i installed guages at about 25 grand. In 52 thousand my pressure has dropped about 1 psi across the entire range. I am not sure if it is the pump or the guage. I will compare guages just to be sure.I am not going to do a think untill the wot pressure gets down to 4 or less.
Old Jul 27, 2006 | 11:47 PM
tanderson2002us's Avatar
From: Newman Lake, WA (But my home is deep in the heart of Texas!)
Originally Posted by billsuerv
Ok, got my Fuel Pressure Gauge installed (from Geno's Garage)! Took a short run on a secondary road after checking for leaks.
I have 15 PSI at idle and light load, 10 PSI running normal down the road (up to 50/55mph on this short trip), and around 5+ flogging it. The truck has 48K miles and I'm connected to the test port on the InjectionPump. Also have 17k miles on the fuel filter. ( I don't the previous owner did, I'm ready to change it but wanted to wait and see what the difference would be on the fuel pressure, before and after).
My question is ;
What is a good reading for a stock pump, and what is an acceptable reading for a stock pump???? Idle; running say 2000 rpm down the highway; and flogging it????
Thanks, this forums been a great help!
I am in the same boat...read post on ".....it happened to me". I have the Westach gauge and was slightly below you. LP rolled over the other day.....truck in shop now. Vulcan kit or other mod. coming after I get it back.......DON'T YOU HATE THE PARANOIA? It stinks having to limp around! Had a cement truck pass me going up a grade last week! Embarassing
Old Jul 28, 2006 | 01:01 AM
Derek Roch's Avatar
13psi or higher idle, no less than 8psi at 2 grand.....
bob95065
Jul 17, 2012 12:27 AM
mstep3
23
Jul 27, 2010 02:22 PM
89dieselkong
Dec 18, 2007 11:38 PM
TexasCTD
Sep 27, 2006 03:14 AM
Txwelder
May 19, 2005 06:10 PM
