Steering Box Problems
Old Aug 5, 2003 | 09:15 AM
Jones0027's Avatar
Diesel Gods,
Has anyone had any problems with their steering box? ??? A buddy has a 2000 RAM CTD and has all kinds of problems with the steering. Apparently, only Dodge makes the parts to fix the issue. : Just wondering if the 2002 has the same issues. So far... so good. 8)
Old Aug 5, 2003 | 09:25 AM
LE's Avatar
LE
Re:Steering Box Problems
My buddy has a 98.5 that had a problem with the shaft being loose. His son works for Car Quest and was able to get the parts to rebuild a "different" housing. If it is leaking, you can get a seal kit. If there is a mechanical issue, I think you are stuck getting a new box or a decent core to rebuild.
Old Aug 5, 2003 | 09:40 AM
royB's Avatar
I don't know what issues he is having, but have you/he looked at Darins steering stabilizer to help with play in the box and take some of the load off it? My steering shaft bushing/bearing had some play in it but was not leaking, I added the stabilizer this weekend and it has eliminated all the play associated with the loose shaft. I still have some play in the track bar but that will be taken care tonight.
Just a thought.
Roy
Old Aug 6, 2003 | 11:03 AM
Diesel Dave's Avatar
I think that AGR (?) makes a replacement steering box for our trucks. I think that there are other companies out there that might also. If you do a search on this site you might be able to find some more information on this.
Old Aug 6, 2003 | 11:09 AM
James Lucas's Avatar
I had one replaced under warrantee that was leaking and I got one now fresh out of warrantee that is starting to go out.
I am definately watching this thread!!!!
James
Old Aug 6, 2003 | 11:28 AM
I have dual front stabilizer shocks... Is that what you are referring to as a help to the steering box? What is the DSS stabilizer shock does it mount differently than standard or aftermarket stabilizer shocks?
James
Old Aug 6, 2003 | 03:38 PM
dodgeram's Avatar
http://www.solidsteel.ca/
http://www.solidsteel.ca/Stabilizer.htm
they have a web site now
Old Aug 7, 2003 | 03:15 PM
GMScott's Avatar
Yep, Nice piece of equipment! I'm not associated with Darin, in any way, just a satisfied customer.
Definitely improved the wander, especially while towing.
Old Aug 7, 2003 | 08:20 PM
DHeadington's Avatar
I had same problem with my steering bushings worn out in second steering box decided to try Darrins bracket. Now truck steers like it has rack and pinion steering no play or dreaded wander that I have had since new. Great with camper behind truck. Highly recommend bracket. I don't work or have any affilation with Darrin's company.
Old Aug 7, 2003 | 11:38 PM
Thanks Gary!!!!
I was about to order one tommorrow......
James
MikeThomas
Feb 19, 2007 10:28 PM
jkap
Oct 23, 2006 04:07 PM
04ctd
Oct 5, 2006 08:27 PM
LanceK
13
Jul 14, 2006 08:08 PM
unioncreek
Jun 29, 2005 02:00 PM
