Steering box
Steering box
When the box was weak in my other dodge I put in a psc steering box. Is this still the box to get? Its been two years since I put the other box in and I wasn't sure if there was something else that was better now.
Thanks
Thanks
Now I think I need two boxes. Mine seems to be leaking fluid all over the place. I heard there is a seal kit for these. does that work? I drained the reservoir in 5 days and 150 miles and it looks like it is leaking on the bottom of the pump where the gear comes out. The thing that puzzles me a bit is that there is fluid all over the engine compartment. I guess that could be any number of fluids.
PSC light steer box IS the one to get. It has a 3 1/4 turn from lock to lock instead of the stock 4 1/2 turn. Much easier to drive these trucks. I also heard that AGR makes a nice box too.
The NAPA boxes wont last that long, its either hit or miss, and they are only a little cheaper than a PSC or AGR box.
Also if you do put a new box on make sure tou put the DSS stabilizer on to, makes a big difference.
http://www.pscmotorsports.com/produc...products_id=92
so you are saying that I want that one and not the one that is branded as for the cummins motor?
which is this one.
http://www.pscmotorsports.com/produc...roducts_id=452
also one of the trucks is a 2wd.
which is this one.
I have went thru 4 ARG steering boxes in 2 years so I would stay away from them all of mine have been under warranty but if it goes again I'm going to a PSC box and give them a try
04ctd
Oct 5, 2006 08:27 PM
LanceK
13
Jul 14, 2006 08:08 PM
unioncreek
Jun 29, 2005 02:00 PM
