Starts hard occasionally
Old Feb 6, 2007 | 07:05 PM
larabeejj's Avatar
I have an 01 dodge that has lately starting hard even when its warm sometimes I can go out to the truck and it will start right up other times it may have to crank a few long times before it fires off runs great oncet it starts. If I shut it off and immediately crank it, it'll start but if sometimes I wait 10 min or more it does it all over again. Its not a constant thing just sporadically happens. I have a low pressure fuel light and a new lift pump so I got good fuel pressure. Maybe bad injector of gettting air in lines I dont know. Thank you for any replies.
Semper Fidelis Sgt Larabee
United States Marine Corps
Old Feb 6, 2007 | 08:22 PM
Tommy93w350's Avatar
Have your batteries check they sound weak.
Old Feb 6, 2007 | 08:54 PM
larabeejj's Avatar
Battery power good just wont fire off
Old Feb 6, 2007 | 09:10 PM
ohiostate24's Avatar
Check your spark plugs.
Old Feb 6, 2007 | 09:16 PM
robert78.5's Avatar
Sounds exactly like mine did. I changed the bypass check valve on injector pump and it seems to have helped. Valve is supposed to hold 14 lbs pressure in injector pump, mine held 0 lbs.
Old Feb 7, 2007 | 11:30 AM
Mikey G's Avatar
I had a similar problem. The air bleed valve on the injector pump (where the fuel line comes in from the lift pump, Looks like a tire air valve but larger) was leeking a small amount of fuel. If I started it up right away, it would fire right up, but if it was shut down for a half hour or longer i'd have to crank it over for 20 to 30 seconds to get it to fire.
Old Feb 25, 2010 | 02:07 PM
larabeejj's Avatar
It ended up being the check valve in sending unit in tank. Bought in line check valve and installed fixed problem.
Old Feb 25, 2010 | 04:41 PM
illEatUrDuramax's Avatar
larabee where you stationed? jw, my brothers in afghanistan right now, just deployed about a month ago IIRC. hes in 3-6
powerrammaster
Dec 5, 2011 12:00 PM
rip 112
May 12, 2009 09:57 PM
wafflehouse
Oct 11, 2007 07:04 PM
Greg@RME
Jul 3, 2007 08:18 PM
