Starter problems
Old Jun 18, 2007 | 09:17 PM
revoaggie's Avatar
Starter problems
I have a 2000 ctd and i have replaced the contacts in the starter, it was wroking great and now it wont start sometimes. the starter turns but it seeps as if it is not catching the gear to turn the motor over. is it the gears or has the starter gone bad, any advice would be appreciated. thanks
Old Jun 19, 2007 | 08:18 PM
roysleight's Avatar
If all you did was replace the contacts then it shouldn't have changed anything with the gear. Make sure you have the starter bolted in straight and tight.
Old Jun 19, 2007 | 10:26 PM
revoaggie's Avatar
i'll double check the snuggness of them bolts... it was working fine for about 3 weeks so i dont think it is the contacts. also a while back when i started it, the starter hit pretty hard when it started... is it possible that i could have a broken tooth on them gears??? thank you for the info.
Old Jun 20, 2007 | 12:53 AM
Deezel Nate's Avatar
Make sure the starter is bolted tight.
I put new contacts on mine in the fall. I was putting a new fuel filter a few months later and I notice the starter looks weird.
Yeah, the thing was hanging by the cables! 1 bolt was gone and the other two where about to fall out too. I had no idea how it was even cranking the truck without noise.
The same thing happened to my steering pump when I replaced that I have learned to use plenty of loc tite.
Darn truck is worse than a Harley!
DJ Turbo.
Oct 13, 2011 09:11 PM
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
