starter
Old Jan 18, 2011 | 08:54 PM
richf's Avatar
starter
starter is going south.truck will start fine 9 out of 10 times but i will get a click once in a while and after the 15th click it will start.i have replaced a lot of marine 5.9 and 8.3 startes but the truck looks a little more difficult.any tips?
Old Jan 18, 2011 | 09:18 PM
Mt Hydro's Avatar
Requires 12 point socket for removal, cant remember what size. Did mine couple months ago, easy job.
Old Jan 18, 2011 | 10:46 PM
Dr. Evil's Avatar
10 mm
dont replace the starter - get new contacts from Larry B
Old Jan 18, 2011 | 11:42 PM
Tate's Avatar
Get a 10mm gear wrench, way easier than a ratchet, faster than a box end wrench.
Old Jan 19, 2011 | 12:33 AM
dodge24's Avatar
I agree with Dr Evil! Save yourself some $$$ and just do the contacts. It's a super easy job and you'll get another 194k out of it! I think mine failed around 134k if I remember right.
Old Jan 19, 2011 | 12:44 AM
nickg's Avatar
finally replaced my starter last week, it went thru 2 sets of contacts, and 517,000kms of starts, 220,000kms of delivery service use, likely stopped and started 20+ times a day for 3.5yrs
Old Jan 19, 2011 | 07:41 PM
Silver R/T's Avatar
Those bolts are tight on there. I had to put a piece of 2x4 on a jack to get one of the bolts off
Old Jan 19, 2011 | 09:47 PM
Mike L's Avatar
The top one is the real beach to get out. I went through the top of the motor bay, very long extension, u-joint and a 1/2"drive impact gun. Took it out no problem. You can even reverse the process to get the bolt started on the new one - just start - do NOT tighten with the impact gun. That you gotta do from underneath.
Cheers!
Mike
Old Jan 22, 2011 | 10:44 PM
AlanF's Avatar
starter
I have had to re and re starter on my truck a number of times. 2x for starter and 2 more replacing crankshaft position sensor. I have tried on a hoist, but find it much easier with the truck on the ground lying on a creeper. I undo the top bolt first, than the lower two. If you don't loosen the bottom bolts, you can crack the top (awkward to reach one) bolt and then twiddle it loose with your fingers. Lower bolts are easy to reach. 10 mm box wrench works fine for me although I did have to use a pipe for leverage as the 10mm is a bit short and the bolts are tight.
Alan
Old Jan 23, 2011 | 12:02 PM
Silver R/T's Avatar
http://cgi.ebay.com/ebaymotors/DODGE...Q5fAccessories
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
MJR
Mar 16, 2003 08:26 PM
