Squealling LP, is it on its way out?
Old Feb 14, 2006 | 06:30 AM
hotdram's Avatar
Turned the key on the other day, about 35-40* outside and the lift pump liked to make a noise I never heard before from it. Started squealling and squalloring so much I thought a cat got caught in the fan belt. Turned the key off and back on again and it still sounded the same. Pressure was okay, 14 psi, just never heard that noise before. Haven't been able to duplicate the noise (even tried throwing the neighbors cat in the fan belt but they pitched a hissy fit).
Anyone else have this happen? Is this a sign of impending doom for the LP?
(by the way, the short anwer to "Is the LP on it's way out" is: "Yes, its in a Dodge fuel system )
~Rob
Old Feb 14, 2006 | 06:32 AM
Geico266's Avatar
Can't be a good sign. Watch the FP for a few days and see what happens. I would get a FP coming though and keep it in the truck just incase.
Old Feb 14, 2006 | 06:40 AM
hotdram's Avatar
Been watching it like a hawk, everything looks and sounds normal. I am still in warranty and not far from the dealer. If it goes, I will let them replace it.
Thanks,
~Rob
Old Feb 14, 2006 | 06:41 AM
hotdram's Avatar
Mods,
Please move this to the correct forum for me
(It was early and I hadn't had any coffee, I thought I was in the 24V engine/drivetrain forum)
Thanks,
~Rob
Old Feb 14, 2006 | 08:39 AM
MKELLY's Avatar
I had a similar noise from what I thought was the lift pump, but it turned out to being the starter staying engaged from worn contacts.
Old Feb 14, 2006 | 10:46 PM
mini14's Avatar
with the cold weather,and the grid heaters cycling, the lift pump will make these sound due to extreme low voltage going to it. those grid heater draw a lot of voltage away from the lift pump. sometimes mine wont even cyccle when temps are around 10 degrees....once grid heaters stop cycling pressure is back up. the grid heaters themselves will squeel sometimes from heating up....sounds normal to me....those in hotter climates tend to disagree my grid heaters cycle about 6 months out of the year so im used to all those strange noises.
jk6140
May 6, 2008 09:53 PM
Djasik
Feb 23, 2007 01:45 PM
BigDave12768
Dec 14, 2006 01:55 PM
West Coast
Apr 18, 2006 09:28 PM
CTD2001
May 17, 2005 07:28 AM
