Speed sensor code??????
Old Jul 11, 2007 | 07:59 PM
R.T.D.H.S.P.'s Avatar
I am throwing a P0500 code? I think this is the speed sensor on the rear differential????? Is this right???? If so, where exactly is it located??? TIA
Old Jul 11, 2007 | 08:43 PM
phox_mulder's Avatar
If your speedo and ABS are working, then you probably set the code by spinning the tires recently.
It is located smack dab on top of the rear pumpkin.
phox
Old Jul 11, 2007 | 08:47 PM
chuntabear's Avatar
It is located in the rear end on top of the pumpkin, it picks up off the ring gear.It is external and only has 1 bolt holding it in. A common problem is the conector it will get corroded.Also check the wire harness where it goes up to the frame ,some times it gets messed up there it rubs on the fuel tank.
Old Jul 12, 2007 | 11:41 AM
Thanks guys..Found it. Cracked plug in. Guess it just couldn't handle all the torque!!! Light are off THANK GOD!!!!
grush
Jan 26, 2011 12:04 PM
bob95065
15
Mar 5, 2009 10:25 AM
Moobesor
Feb 23, 2008 09:57 AM
sjester
May 10, 2007 05:03 PM
Tommy93w350
Jun 2, 2006 09:47 PM
