Speed limiter
Old Apr 5, 2005 | 09:01 PM
dieselrob's Avatar
Speed limiter
Hey guys i was just curious on the top speed of our trucks. Is there a speed limiter, if so whats the limited mph. Im thinkin bout hittin up a strip this weekend to get some runs in if the weather holds off.
Old Apr 6, 2005 | 06:12 PM
phox_mulder's Avatar
I don't think there's a speed limiter per say, but a rev limiter which would eventually limit the top speed.
Shouldn't have a problem at the track.
phox
Old Apr 6, 2005 | 06:46 PM
BigBlue's Avatar
I can do 105mph at 2500 rpms. I've had it up to 115 before. That was with 33's though and an uncorrected speedo. The 105 was with 35's and a corrected speedo.
Old Apr 6, 2005 | 07:41 PM
dieselrob's Avatar
hey big blue what gears you got in that thing 3.54 i assume. i have the 4.10s and also an uncorrected speedo.so not shure what speed im ever doin.
Old Apr 6, 2005 | 08:18 PM
KatDiesel's Avatar
I have no problems doin 110mph (4.10gears & 285/75/16 tires). After that can't keep eyes off of road long enough to check speedo & tach but certainly running out of RPMs, speedo corrected at dealer.
Old Apr 6, 2005 | 09:19 PM
Scubasteve's Avatar
I had mine up too 200 km/h(Approx 120 mph) but the freakin cars were wizzing by so i backed out of it..
I really dont think there is a speed limiter on the diesels, if there was it would kick in at 95 mph..
Jason
Old Apr 8, 2005 | 10:46 AM
92redyj's Avatar
Ive hit 120 at 3k rpms and it wouldnt go any more, did not feel like it was hitting a limiter though
Old Apr 8, 2005 | 12:22 PM
tool's Avatar
I believe governed engine speed is the only "speed limiter"
At least I haven't found any other
Old Apr 8, 2005 | 04:38 PM
paulb's Avatar
My 02 would start to defuel at 109. You could see it on the EGT's. After installing the RAD the EGT's no longer start to drop at 109. I'm not sure what years do this though...
Paul
Old Apr 8, 2005 | 04:47 PM
tool's Avatar
Hmmm, but is that due to speed or RPM??? What engine RPM would you be turning at 109?
Old Apr 8, 2005 | 06:53 PM
johnh's Avatar
Smile speed
i can go 113, i think if i had an edge drag box instead of a comp i could go more. but 113 is too fast for traveling.....75 or 80 is just right on the interstate
Old Apr 8, 2005 | 08:38 PM
44-40's Avatar
Mine started dying at 105.
Old Apr 9, 2005 | 02:42 AM
killfast1's Avatar
I have had mine up to 120. Its kind of scarry but cool also.
I do know the cruise control is limited at 85 mph.
Old Apr 9, 2005 | 10:48 AM
Jetpilot's Avatar
The truck does have a speed limiter. Some are programed different than others but usually it is 115 mph, some are as low as 95 mph. You can use a BD RAD to have unlimited speed up to the rpm govenor or you can cut the speed limiter wire itself. Caution though if you cut the speed limiter wire your grid heaters do not operate correctly (they will cylce a lot more).
For really high topend use a BD RAD and a Blue Chip Redline box and spin it to 4000 rpm
Doug
Leon441
13
Mar 26, 2006 10:11 AM
CrashCade
Jul 5, 2005 01:32 AM
lit up
Nov 27, 2004 11:36 PM
ARAcummins
Oct 24, 2004 09:30 PM
Ttexas25
31
Sep 30, 2004 08:48 AM
