South Bend Clutch Problem
Why? Just buy a good clutch and be done with it.
Expense aside, not using the available and top of the line hard parts in a driveline rebuild is looking for trouble.
Start with replacing the rear main, the Cummins seal is the best bet.
Broach the flywheel and upgrade the Input shaft (pilot bearing). The Stock offering is junk, second would be SBCs' idea and top of the bearing picks would be the offering from Quad 4 X 4 (Dans bearing is a whale compaired to the SBC bearing and it has a bronze bushing too).
The input bearing needs major attention, it supports a great deal of weight and when it goes, transmission problems are not far behind.
If you are out driving your truck jamming gears and trying to keep up with the Mustang next to you, be prepaired to pay the price for your efforts.
Peter with SBC knows his stuff. Tell him how you drive and he will get you what you need.
I use the FE O. This is my second 0, the first lasted 140K pulling a 9K 40' gooseneck. It looked good considering the abuse but the SBC sealed bearing was my problem. It went away and the trans went with it.
My second clutch was a SBC twin disc (my idea and it was not a good idea
Peter warned me and I didn't listen) that broke the input shaft, leaving me stranded in Mass for a week.
I now have all new hard parts @ 264,000 and look forward to the next 250K at which time I'll let you know how it went.
Changing the trans lube is very necessary. I use Royal Purple and change it every 25K along with the diff.
Enjoy the ride.
Enjoy the ride.
Mcyktor98
13
Nov 25, 2008 06:47 AM
RFR2212
Jun 14, 2007 02:35 PM
