Smelling Antifreeze when engine warms
Old Nov 22, 2009 | 02:55 PM
leeboy's Avatar
The last few weeks, since its gotten colder, i have noticed a light smell of antifreeze coolant when the truck gets to the temperature where the temp gauge is pointing straight up( just before the fan kicks in i guess) As soon as i smell it, i look at the gauge, its straight up, then it slowly cools...down to normal. Thats the only time i smell it, then the rest of the drive its gone.....With the heat on or off..i only smell it for the quick instance.....Any ideas? Or anything to look at?
Old Nov 22, 2009 | 04:02 PM
dozer12216's Avatar
Heater core leaking. Eventually you will find the green puddle. It is a long way in to the core. Replace the instrument cover if cracked at same time. It comfortable with AC, you might as well do the evaporator and be done with all that goes broken in the dark. JMHO
Old Nov 23, 2009 | 09:32 AM
leeboy's Avatar
IF it is the heater core.....Can i do it myself? Or is that a shop job......? What else could be giving me a little wiff of antifreeze.....? Lee
Old Nov 23, 2009 | 02:58 PM
dozer12216's Avatar
Well, you could be parking at same spot that someone spilled green stuff on.
Old Nov 23, 2009 | 09:22 PM
RAMMINVA's Avatar
my truck runs between 184 and 190 it seems like. Sometimes right when it warms up it will jump to 195-197 and then come back down to 184-186 but won't do that any other time except for right when it warms up. Normal?
Old Nov 23, 2009 | 09:41 PM
lovinCTD59's Avatar
Sounds normal, thats just the thermostat opening. Mine does it too the first time i take it out in the mornin.
If there are no other leaks it sounds like the heater core. I have been smellin antifreeze going on my 2nd winter. Im trying to get to replacing it before this winter really starts.
Old Nov 25, 2009 | 07:44 PM
graphitecumnz's Avatar
most likely the core.... are you having any issues with the defrost not working very well or not getting much heat out of the vents??
We just replaced the heater core in my truck on Saturday... it's a heck of a job. The dash needs to come out.... it actually rolls forward but it's a task....
Old Nov 26, 2009 | 10:38 AM
leeboy's Avatar
I havent had any steam or heat problems yet......No dripping....How many hours to do the job if it is a heater core? My buddys shop quoted 7 or 7.5
Old Nov 26, 2009 | 01:25 PM
sounds close on the hours....
Old Dec 3, 2009 | 02:49 PM
Big Blue24's Avatar
I think it books out to 6 hours.
Old Dec 3, 2009 | 10:13 PM
lovinCTD59's Avatar
I just got done doing mine outside today, it was 22 degrees and snowin by time I finished it. Ahhh I Love Minnesota!!
It took me about 4.5-5.5 hours with removing the heater box, cleaning all the "leaves and trees" out of it and installing a new evaporator core along with a new heater core.
Sure am glad that I replaced the Evap core also, that had its own jungle and creatures in it.
Not a hard job, just time consuming....
Old Dec 4, 2009 | 09:03 AM
leeboy's Avatar
Thanks guys.....I will keep my eye on the floor for green koolaid
Old Dec 4, 2009 | 03:58 PM
lovinCTD59's Avatar
On my heater box there seems to be a vent or a drain coming out of the firewall. I would think antifreeze would come out there first??
troehl
17
Jul 18, 2022 08:27 AM
AttilaTheHun
Sep 15, 2009 01:43 PM
DECJ
Sep 14, 2009 06:49 PM
mx684
Feb 18, 2007 04:13 PM
memphisaudio
Oct 11, 2003 01:00 AM
