SIGNS OF A BAD INJECTOR PUMP
Old Oct 27, 2003 | 08:07 PM
Agades's Avatar
Re:SIGNS OF A BAD INJECTOR PUMP
a stumble doesnt necessarily mean that the pump is bad
but codes,hard starts,dead truck most likely does
there is a "hotwire" test also
pin #6and #7 are your huckleberries
Old Oct 28, 2003 | 08:17 PM
cmckinney's Avatar
Does anyone have the list that deciphers the codes you get if you any. I know I saw a list around a month ago.
-CM
Old Oct 28, 2003 | 08:34 PM
phox_mulder's Avatar
For a 2002, this is the best, most accurate one I've found.
http://www.troublecodes.net/chrysler/96-01.shtml
Supposed to be only up to 2001, but everything I've seen matches.
(clincher is the P1693, if the list says anything about turbo circuit, the list is incorrect)
phox
Old Oct 29, 2003 | 12:19 PM
BigBlue's Avatar
What does the P1693 code mean then? I thought it was a problem with the MAP sensor.
Old Oct 29, 2003 | 04:23 PM
[quote author=BigBlue link=board=4;threadid=21440;start=15#msg203089 date=1067451597]
[/quote]
Just means that a code is present in the "other" computer.
For instance, the PCM gets a 0500, no Vehicle Speed Sensor input.
You run the codes and get an 0500 and the 1693.
1693 just means that code is also in the ECM.
Most likely set up that way so you don't see the same codes over and over when pulling them.
phox
RobG
57
Mar 6, 2018 06:56 PM
mstep3
Jan 22, 2011 10:24 PM
CTDowerTN
Sep 4, 2007 01:02 PM
kycurs
Jul 22, 2006 07:13 PM
MJDiesel
Nov 29, 2005 04:56 PM
