Should I remove Fuel Filter Housing?
Old Dec 12, 2009 | 11:36 AM
steamfitter's Avatar
Should I remove Fuel Filter Housing? the wiring and the old lp once i'm running the FASS pump?
Old Dec 12, 2009 | 12:12 PM
birddoctor's Avatar
Its really just a personnal choice.I took all that stuff off of mine.Gave it more room under the hood.Couldnt see carrying all that around when I wasnt using it anyway.
Old Dec 12, 2009 | 01:10 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Just remember to not take the bracket off for the factory lift pump cause it also serves as a blocker plate and you will develop a nice big oil leak.
Old Dec 12, 2009 | 09:54 PM
johnh's Avatar
i retained mine just for the fuel heater
Old Dec 14, 2009 | 02:56 PM
RowJ's Avatar
Many in cold climates have removed them with no problem i'm aware of ... but fuel heater makes sense if your far enough north.
I never regreted removing mine. The extra space for reaching in to do work is a BIG PLUS!
RJ
Old Dec 14, 2009 | 04:22 PM
Tate's Avatar
I'm still running mine. Extra filtration can't hurt.
Old Dec 14, 2009 | 05:36 PM
Grider Pirate's Avatar
I removed it. I also removed the bracket, then cut away the portion that wasn't needed to block the mechanical lift pump hole in the block. It makes reaching some of the bits (OP sender, MAP, and IAT) a little easier.
Old Dec 15, 2009 | 12:57 AM
thanx for all the input much appreciated.
Old Dec 15, 2009 | 01:34 AM
I might reroute mine so it goes through the fuel heater it was 9 degs. last week thanx.
Old Dec 15, 2009 | 09:43 AM
AH64ID's Avatar
If you remove it you need to change the f/w sep on the FASS. The one on there is not tested by Fleetguard and the specs aren't known. Put Baldwin BF1212 on there.
onelugnut
Jan 11, 2010 07:51 AM
Opacity
18
May 15, 2008 11:54 AM
Tiara3100
Dec 21, 2007 01:42 PM
HOHN
Dec 7, 2003 02:07 PM
