Short to ground problem!!
Old Jul 29, 2006 | 10:46 AM
mgstroker95's Avatar
Question Short to ground problem!!
Does anyone know what would cause a short to ground only when the ignition switch is turned on? Also the short is in the #1 50amp fuse terminal in the PDC which runs into the cab to the instrument cluster. I am curious to know if maybe the cluster is bad or maybe the ignition switch is causing the problem, I am not to sure but I am going to keep trucking ahead with the voltmeter and see what I can find. Maybe someone has an idea! Thanks
DJ Turbo.
Nov 5, 2011 12:20 AM
TankerIP
Feb 26, 2011 08:17 PM
JVDodge
0
Jan 5, 2008 07:19 AM
nancym
Aug 20, 2003 08:40 AM
